Advice on deck cleaning and blade changing
   / Advice on deck cleaning and blade changing #1
erda
Alberta
Kubota B2601
Yard and lane take about 4 hours to mow and is far from smooth or level. There are some significant side slopes as well.
I know that mowing while the yard is damp isn't the best, but at times I don't have much choice.
Currently have a Husqvarna GTH52XLS that I have to pull the deck in order to clean and change blades. This wasn't too much of a problem in the past, but due to injuries I now have limited mobility.
I've been considering a ZT or a front mount with a 'flip up deck' to make the job easier.
Any advice would be greatly appreciated.
   / Advice on deck cleaning and blade changing #2
I don't have any advise, per se, but only to agree that I wish I had an easier way to clean my deck after mowings, (especially when damp), as I know that having the underside clogged up with trimmings is not good, for a variety of reasons. My Husqvarna LGT24K54 has a quick-connect hose attachment on top of the deck, but, event 45-60seconds of water pumping in with the blades spinning does not clean it out that well. Seems the only reasonably way to prep for my next mowing is to take off the deck each time and clean it properly.
Good luck!!!
   / Advice on deck cleaning and blade changing #3
The cleanest I ever got the deck on my F-935 was to mow down a bunch of willows that were about 2 feet tall and had been burnt the previous fall. The burnt willows were dried out and when I went through with the mower they cleaned off all of the stuck on grass.
Has anybody had success with spraying under the deck with say WD40 or Pam to keep the grass from sticking?
   / Advice on deck cleaning and blade changing #4
Yes pmsmechanic, I've not only tried WD40, but also silicone, painting with aluminum base paint, and just about every other suggestion that I've read about. None seemed to work well, but then, I do have a habit of cutting grass when its wet or damp. Not a good thing.
The thing that I know for me that works well is a putty blade and some elbow grease. Power sprayer also does a good job, but that means that I have to lift the mower up high enough with my cherry picker to clean it good without getting a bath myself.
   / Advice on deck cleaning and blade changing #5
I've never worried too much about a clean deck.
With few exceptions, I only clean it when I take it off for winter or when I sharpen blades.
I figure most caked on grass gets "sand blasted" by other dry grass, twigs, sand, dirt etc... sooner or later as long as I don't repeat mowing wet grass too much.
There have been exceptions when there was just too much built up. Often just idling down or start/stopping mower deck will introduce enough vibration to rid a lot of it.
OP should look into using a mower lift to raise front of his mower to clean it. Looks like prices range from ~$60 to $200
mower lift - Google Search
   / Advice on deck cleaning and blade changing #6
Hoisting a machine makes for easier cleaning of decks and undersides, but I would be concerned about oil and gas going places they aren't supposed to.
   / Advice on deck cleaning and blade changing #7
A ZTR or front deck rig will certainly speed up your process, if you have the funds. If money is not an issue, I don't know what you're waiting for.
Another thought, if your B has a FEL, they make great mower lifts for deck maintenance. Just remember to also add a mechanical lock while underneath. I've never found any spray or coating to be effective against wet grass sticking to a deck. As mentioned before, a scraping device & some elbow grease works best. I use a small off-set tile trowel to scrape mine, while my BX FEL is used as a "jack" to get it up in the air.
   / Advice on deck cleaning and blade changing #8
I have the 48 (YTH2448 ) nch deck, I tried repainting, spraying with Teflon coating, wd40, oil over the years since 2006. I added a nozzle for hose cleaning even created a ramp to crawl underneath to clean my deck-nothing really worked for very long. My yard is similar to yours but half the size. IMO the only way to do this with relative ease is to buy a mower lift, when the mower clogs up pull up to the tire racks on the lift and lift as high as it will go. Then I grab a broom handle and tape a scraper to the end and clean the deck without getting on my knees or crawling under anything (takes about a minute). My lawn is pretty wet and I will have to do this a couple of times but works well. Also have to tie up the deflector on the chute exit to help keep exit portal clean.
   / Advice on deck cleaning and blade changing #9
   / Advice on deck cleaning and blade changing #10
I too only clean my decks at end of season or if I have the deck off and up in the air for a blade issue. And then only a cursory cleaning.
2121 (A51244)
2121 (A51244)
2016 Ford Escape AWD SUV (A50324)
2016 Ford Escape...
2017 Taylor-Dunn B0-248-36 Electric Utility Cart (A50324)
2017 Taylor-Dunn...
2011 BMW 328xi AWD Sedan (A51694)
2011 BMW 328xi AWD...
Appalachain 2 Axle Fender Trailer (A50774)
Appalachain 2 Axle...
2014 Nissan Maxima Sedan (A50324)
2014 Nissan Maxima...
