Advice on clearing composted leaves
   / Advice on clearing composted leaves #1
EgregiousAardvark
None
I was tempted to write a 'which tractor should I buy' post but I'll take a different tack and go with the application. I'm purchasing a small lot (Between half and 3/4 acre) that is >50% overgrown brush and leaves. Some spots have a foot or more of leaves and brush from years of neglect. I'd like to create more cleared space for the kids and improve what's already there. The attachment shows what a good chunk of the lot looks like.
What methods/implements would you folks recommend for clearing the brush/leaves down to bare soil? I've pondered a larger GT with a 3PH/ box scraper, but I may be going down the wrong path. Hopefully the GT would transition from clearing/landscaping to maintenance of a higher quality area. (Big hope, I know!)
E.A.
   / Advice on clearing composted leaves #2
I use drip torch. Seriously, I don't know where you are but the best option is a controlled burn.
   / Advice on clearing composted leaves #3
With out a tractor you’re in for a good bit of manual labor.
In my opinion, beyond a necessary chain saw, a small utility tractor with a FEL and grapple attachment are in order.
Now the downside, that level of equipment will chew up about 40 to 50K and is a lot of money to invest for an acre or less.
Depending on your long range plans, I’de shop around for a local guy or landscape outfit experienced in land development and let them have at it.
B. John
B. John
That's fair. I was tempted to go with a solo approach to save money but it might be pound foolish rather than have it done by someone with a SCUT or skidder.
   / Advice on clearing composted leaves #5
Do you live on the property or is it adjacent to a parcel you already have? Point is how convenient is it for you to work on clearing it out? Do you have other property to work/maintain?
Is it property I'll be moving to this summer. The house is at the front of the property with a fairly small footprint. The project could be done over time if it makes sense and I will be my only project of the sort.
   / Advice on clearing composted leaves #7
Well the above advice is good but if you are living there and if you have time you could clear it quite a bit without a lot of equipment if you don’t expect it to look like a park in 30 days. Just depends on the level of clearing you want to do.
Of course, the option to hire some one to do a lot of the initial heavy clearing would be sound too.
Do you have burning restrictions where it’s located? I’m not thinking a controlled burn on the whole place at once but can you burn piles of leaves and brush from time to time?
   / Advice on clearing composted leaves #8
Personally I would hire someone with a skidsteer to come in and clean it up. Shouldn't take them long (maybe 4-8 hours) and go from there. No since in buying a machine, a garden tractor won't touch it.
   / Advice on clearing composted leaves #9
1/2 acre is not that large. It looks like vines and small saplings. I've done it by hand with a chainsaw, pruning hooks and a garden cart. Helps to have child labor, too. :laughing:
Or rent a small tracked excavator with a thumb for a weekend rental. It would make short work of that for less than $500 for the weekend.
Or, as others have said, see how much a local person with equipment would charge you.
Again, 1/2 acre is not that big.
   / Advice on clearing composted leaves #10
Oh, we forgot to say welcome to TBN! :thumbsup:
2005 KENWORTH T800 (A52472)
2005 KENWORTH T800...
2017 E-Z Beever M12R Towable Brush Chipper (A51691)
2017 E-Z Beever...
1995 Chevrolet K2500 Pickup Truck, VIN # 1GCGK29F2SE237154 (A51572)
1995 Chevrolet...
UNVERFERTH 330 8 AND 1/2 INCH EXTENSION STUB TUBE WELDMENT FOR FRAME (A52748)
UNVERFERTH 330 8...
2009 IC Corporation PB105 Passenger Bus (A51692)
2009 IC...
New Wolverine72 In Skid Steer Brush Cutter (A53002)
New Wolverine72 In...
