Advice on Cat III
/ Advice on Cat III #1
icandoit
Flatonia,Tx, USA
1978 JD4630
I need the experts advice. I have a 1978 JD4630 at 150HP. A Cat III. Everything I look at as far as Box Blades, Bush Hogs, Post Hole Diggers,and Landscape Rakes are made for either Cat I or II. Can I use a Cat I or II with my tractor? My PTO is running at 1000 RPM so that is a BIG concern. If the implement is made for a 540 RPM, I'm done. But what about the other implements that aren't PTO driven? Could a little welding here and there make a Cat II work on a Cat III? Thanks for any advice.
Dick
/ Advice on Cat III #2
</font><font color="blue" class="small">(
Dick )</font>
There's equipment made for CAT III tractors. They'll be EXPENSIVE to say the least. You MAY get away with a few CAT II impliments, but with that tractors added weight X HP, you'll gut most equipment in minutes without so much as any effort.
SOME 540 RPM equipment (BIGGER balers, choppers, ect..) can be geared up or down for 540/1000 RPM use. But unless they're factory built to accomodate that sort of grunt, you're risking serious injury when you TRY to hook light-weight equipment to power like that.
I have a 4955 Deere (205 PTO HP) I TRIED ditching a drainage ditch with a CAT II, 3-bottom plow a couple years ago. I THOUGHT I could just go easy, and not hurt a thing. I "pretzeled" the plow in about 2 minutes. Never felt a thing.........
There's a reason why they put CAT III hitches on those big boys!
/ Advice on Cat III
Hmmm, I was afraid someone would say that. Do you happen to know of a place where I can get these implements for a Cat III hitch.
Dick
PT 1000 Gallon Supply Tank (A57149)
PT 1000 Gallon...
Toro Greenspro 1260 Towable Greens Roller (A56859)
Toro Greenspro...
2012 Peterbilt Semi (A64047)
2012 Peterbilt...
2021 CATERPILLAR 279D3 SKID STEER (A62129)
2021 CATERPILLAR...
John Deere Mirror and Light Kit (A63116)
John Deere Mirror...
500 BBL FRAC TANK (A58214)
500 BBL FRAC TANK...
