Buying Advice advice on buying Kubota L1500
   / advice on buying Kubota L1500 #1
bgswamp
Kubota L1500
Hello everyone,
I googled this model tractor and this site was one of the results. I spent 5 minutes and found out there is a ton of info all around, so I wondered if someone could give some guidance. I found this L1500 tractor that I believe is a grey model L175. It comes with a 5' finish mower in excellent shape. He has a set of turf tires on it, but he also has the ag tires on rims that would come with it as well. He wants $1000 for all. I know this gentleman and as far as I am concerned his word is gold, so I am not concerned about the shape of the tractor. He says when he parked it three years ago it was running fine. What I would like to ask is: 1. Is it worth this price? 2. Should I worry about it sitting up for 3 yrs./ What should I do before I crank it? 3. Will I be able to find parts from a local Kubota dealer? Thanks to anyone for any help!!
   / advice on buying Kubota L1500 #2
I think at that price its a great deal as long as it runs. To get it running probably 2-3 gallons of fresh diesel and a new battery would be in order - draining the old fuel and changing the fuel filter.
These vintage had a decompression knob and a button for the glow plugs and usually a combination of that and a decent battery it should start - it will sound rough for the first minute or two as its a 2 Cyl but at 1500 RPM it should be fairly smooth.
Of course check the oil too before starting should be black without any yellow (water) - if in doubt change the oil too. The only other things to check would be the coolant level and hoses as a unit this age might have some cracked or checked hoses.
Overall a great deal at that price - even the 5' finish mower in good shape is worth $600+.
Thanks Carl. That's great advice. I am going to go today to see what I can do with it.
   / advice on buying Kubota L1500 #4
How did you make out with the 1500? Does it have a new home now? Post some pics if it does!
2020 HYUNDAI TRANSLEAD 53X102 REEFER TRAILER (A52576)
2020 HYUNDAI...
Power Liner 4000 Paint Striper  (A52384)
Power Liner 4000...
DROME EXCAVATOR SLIDE ATTEHMENT (A50322)
DROME EXCAVATOR...
2011 Autocar ACX64 Xpeditor coe t/a refuse (A52384)
2011 Autocar ACX64...
WEILER B670 FELLER BUNCHER (A51246)
WEILER B670 FELLER...
