Advice on boxblade size ?
/ Advice on boxblade size ? #1
fargo
JD 3720
I'm purchasing a John Deere 3720 (44hp), which has a track width of 59.1 inches (~5ft) and would like to purchase a boxblade.
Looking for advice on wether to purchase a 5 ft or 6 ft boxblade.
Has anyone purchased a 5ft and found it slightly short in covering the footprint ?
5 ft Medium duty, 515 lbs ($599)
6 ft Standard duty, 575 lbs ($791)
Thanks in advance
/ Advice on boxblade size ? #2
The 5' should do you fine, but you may just want to go to the 6ft because it will get even closer up to fences, or other areas that you may need to work.
In my mind, you have enough power to handle the 6 footer without difficulty, but some extra tough soil may make it necessary to raise a couple of the scarifiers if you have trouble digging. I'd go with the 6' if you have a lot to do, the 5' if you don't.
John
/ Advice on boxblade size ? #3
The 6' would work fine for your size tractor. It will not only do a good job grading, but will also be able to handle it full of dirt.
/ Advice on boxblade size ? #4
I use a 5' behind my relatively light weight 30 engine HP Kubota B2910 with pretty good results...
If it were me, with a tractor your size I would go with the 6' and not blink an eye... /forums/images/graemlins/smile.gif
/ Advice on boxblade size ? #5
I would bet that 59.1" is minimum wheel spacing on a 44hp tractor, and that they would expand or reverse to more like 6', so I would definitely go with the 6' boxblade.
2016 Deere 180G (A60462)
2016 Deere 180G...
159115 (A60430)
159115 (A60430)
John Deere 2155 (A62177)
John Deere 2155...
445 (A63290)
445 (A63290)
2021 Kubota MX6000 (A62177)
2021 Kubota MX6000...
John Deere Cotton Picker Catwalk Floor and Railing (A63116)
John Deere Cotton...
