Advice on a truck
   / Advice on a truck #21
<font color=blue>Oh, what does the "1500" mean? Is that a 3/4 ton capacity?</font color=blue>
Its a 1/2 ton.
I echo every one else that you cant go wrong for $500.00
______________________________________________
Take care, Jim
   / Advice on a truck #22
If they can crank it under the hood it isn't the solenoid. Try the ignition switch or, more likely, the clutch safety switch.
   / Advice on a truck #23
Oops, I read the book wrong. The 292 I6was offered up through 1986, but not 1987. They came out with the 262 V6 in 1985 and the 292 and 262 were both available in 1985 and 1986. In 1987 they dropped the 292. In 1985 they changed the body style to a slightly more aerodynamic hood and fenders. So, in 1984 it was either a 250 or 292 and it had the more squared off front end.
   / Advice on a truck #24
<font color=blue>Just pop the hood and grab the linkage arm on the column and lift</font color=blue>
Brings back memories of my '73 Chevy truck. You'd think they'd have fixed that problem by '87. A girl I dated in college knew this trick from an even older car her parents had /w3tcompact/icons/smile.gif
   / Advice on a truck #25
<font color=blue>Oh, what does the "1500" mean? Is that a 3/4 ton capacity? </font color=blue>
This is my unofficial guide to "American made" truck decifering:
If the model begins with a "1", then it is a 1/2 ton (10, 100, 150, 1500, etc).
If the model begins with a "2" then it is a 3/4 ton (20, 200, 250, 2500, etc).
If the model begins with a "3" then it is a 1 ton (30, 300, 350, 3500, etc).
Dodge 2wd pickups begin with a "D" while the 4wd models begin with a "W" and the vans begin with a "B" (D150, W250, B350, etc).
Ford trucks begin with an "F" and the vans begin with an "E".
Chevy trucks begin with a "C"; I think this is true also for GMC trucks also but I can't remember. I also can't remember what the Chevy vans start with.
Hope this helps for anyone truck shopping...
Kelvin
   / Advice on a truck #26
<font color=blue>Chevy trucks begin with a "C"; I think this is true also for GMC trucks also but I can't remember. I also can't remember what the Chevy vans start with.</font color=blue>
GM vans are "G" and 4X4 trucks are "K" /w3tcompact/icons/smile.gif
   / Advice on a truck #27
RobS,
Thanks for the additional information. As you can probably tell, I have more familiarity with the Dodge products than the other offerings.
Since I made the post, I have noticed that since Dodge came out with the new design in 1994 that they quit putting the "D" and "W" in front of the 1500, 2500, and 3500 on the truck. I don't know if the "D" and "W" are still part of the model number or not.
Kelvin
   / Advice on a truck #28
Kelvin, I'm not sure if Dodge still uses the W and D or not either. The marketing names are different than the internal code names anyway. The previous Dodge was the BR and the newest one is the DR. Ford has all sorts of platform names for thier trucks and I've pretty well lost track of GM lately /w3tcompact/icons/smile.gif
2000 Nabors 40 Ton T/A Flatbed Equipment Trailer (A55973)
2000 Nabors 40 Ton...
2023 New Holland CR10.90 Combine - 332 Engine Hours - 244 Separator Hours (A56435)
2023 New Holland...
1992 CATERPILLAR 14G MOTORGRADER (A52709)
1992 CATERPILLAR...
Portable Restroom (A54865)
Portable Restroom...
2012 International Derrick Digger (A55973)
2012 International...
40ft High Cube Shipping Container (A57453)
40ft High Cube...
