Advice Needed from 2710/2910 Owners
   / Advice Needed from 2710/2910 Owners #1
ncengr
Guilford County NC
Kubota B2710
Hey y'all. I need help from your experience. I am finding that some 3ph equipment cannot be used with my B2710 due to the adjustable stabilizer arms on the lower links. The arms being on the inside of the lower links limit how wide an implement can fit in there (even though the lower links can spread far enough apart to hook to ordinary Cat 1 implements). Are others seeing this as a problem and what if anything are you doing? Many thanks!
   / Advice Needed from 2710/2910 Owners #2
Steve,
I haven't run into that problem with my B2910. The Cat. 1 equipment I use with it are:
Woods 1160 Post Hole Digger
Woods SS60 Snowblower
Woods HB60 Boxblade
Howse carry-all
Howse boom pole.
All of this equipmet fits fine. The Woods post hole digger has Cat 1 pins pointing inward and Cat 2 (I think) pins pointing outward. The arms can't spread wide enough for the outward pins but they reach the inward pins fine.
~Rick
Thanks Rick. I have no trouble with my RFM or box blade but my carryall (Leinbach) and rear cultivator (homemade) will not fit due to angle iron bracing that extends out from the implements towards the tractor and are hitting the stablizer arms. Both of these worked w/o any problems on my old 8N and I was counting on being able to use them with my Kubota.
The carryall is a fairly typical design and I'm curious if other 2710/2910 owners are finding any implements that interfere with these stabilizer arms. I love my 2710 and other than this design issue it is a great tractor. Thanks!
   / Advice Needed from 2710/2910 Owners #4
I have not experienced that problem with any of my implements.
   / Advice Needed from 2710/2910 Owners #5
Steve
I have noticed the bracket that releases the adjustable links are very close to the frame of some of my attachments. But haven’t had one that would not attach.
Mini Jack Daniels Truck (A55853)
Mini Jack Daniels...
2005 Isuzu NQR 4 door box truck with folding gate (A56436)
2005 Isuzu NQR 4...
2005 EZ-GO Utility Cart (A55853)
2005 EZ-GO Utility...
Honda Pioneer SXS700 4X4 Utility Cart (A55758)
Honda Pioneer...
ELECTRIC GOLF CART (A58216)
ELECTRIC GOLF CART...
2020 DRAGON ESP...
