advice needed for NAA front pump for log splitter
   / advice needed for NAA front pump for log splitter #1
pknapp
ny
ford naa
I recently hooked a log splitter up to the original front FEL pump on my ford NAA. The 4 inch ram on the splitter is a bit slow for
my liking. I was wondering about a cheap replacement and came across this pump on Ebay# 391285148583. Sorry I don't have enough
posts to attach links. It is a 21 gpm bidirectional pump. Was wondering if this would speed up my splitter and still operate the front loader properly.
Not sure why it has a rear drain port? Any other inexpensive options out there?
Thanks, Pete
   / advice needed for NAA front pump for log splitter #2
That pumpis rated at 21gpm@3600 rpms. How many rpms does your tractor run. Less rpms equals less gpm with that pump. Not sure the speed of your engine but I suspect you would only get about half those flow numbers.
My tractor currently flows 5gpm so I am hoping that even running this slower than 3600 will still exceed my current 5 gpm's by a substantial amount. I chose this pump because it has the highest flow of the ones listed. Not sure exactly how the plumbing would work seeing that this pump has a drain port?
2018 FORREST RIVER CRUISE LITE CAMPER (A52472)
2018 FORREST RIVER...
2002 KENWORTH W900 TRI AXLE (A52472)
2002 KENWORTH W900...
(1) 14ft Tarter Gate (A51573)
(1) 14ft Tarter...
Kubota RTV500 (A47384)
JOHN DEERE 333G SKID STEER (A52472)
JOHN DEERE 333G...
