Disc Harrow ADVICE: Disc For JD 2030 68 HP Tractor
   / ADVICE: Disc For JD 2030 68 HP Tractor #1
bodin1968
Montgomery, AL
1968 John Deere 2020
need recommendation (cutting width, weight, manuf.) for disc harrow for a JD 2030-68 hp tractor 2wd. will be working in a sandy clay loam in black belt, middle alabama. thanks in advance.
   / ADVICE: Disc For JD 2030 68 HP Tractor #2
LMC .. built here in Alabama. 8 ft'r is what i pull with my 46hp. Look at the 500 series or the HD series. if ya ride up to Cullman flea market at the 308 exit you can see a ton of them in stock all sizes.
LMC Disc Harrows
Good well made used heavy harrows are scarce in our area. I looked for almost 2 years before I found a good used one and it was $1100.
good info thanks... what's ur opinion on Brown outta ozark or bush hog discs?
   / ADVICE: Disc For JD 2030 68 HP Tractor #4
I have a 70hp old IH 2wd and it pulls a 10 foot disc and doesn't even know it is back there. Would feel very comfortable going up to 12 no problem.
   / ADVICE: Disc For JD 2030 68 HP Tractor #5
I cannot help with first hand info on Brown, but, I have never heard anything negative!
Leo
2013 Dodge Charger Passenger Car, VIN # 2C3CDXATXDH646719 (A51572)
2013 Dodge Charger...
(10) Replacement Thumb Cylinders (A51573)
(10) Replacement...
JOHN DEERE XUV590M LOT NUMBER 27 (A53084)
JOHN DEERE XUV590M...
Neckover GL24-2-7K Gooseneck Trailer  24ft Deck, Dual 7K Axles, 14K GVWR (A53472)
Neckover GL24-2-7K...
(1) HD 24ft Free Standing Corral Panel (A51573)
(1) HD 24ft Free...
2018 Taylor-Dunn BigFoot B5-440-36 Electric Utility Cart (A50324)
2018 Taylor-Dunn...
