Advertising in the threads. Template sent. moved to mm
   / Advertising in the threads. Template sent. moved to mm #1
Magister Hydraulics
Advertiser
Belleville, NJ
Hello,
There is aftermarket Task Master Hydraulic Cylinders available on eBay. You can search WLD-TTT 1.5x22.25 in the search bar.
Re: Leaking lift cylinder LA450 Front End Loader
Spanner wrenches are normally used to open the gland of the cylinder. You will just need to know which size you will need as these come in different sizes. Grainger and northern tool has some i believe. Might find some cheaper on ebay.
Re: Loader bucket cylinder replacements
There's a few variables to consider.
When replacing the tilt cylinders, You want to make sure that both cylinders are operating at the same speed and have the same stroke and length. Having cylinders working against each will put them as risk of bending or causing other damage. As long as the cylinders are the same you should be fine. Although sizing down isn't almost never recommended, as long as the load isn't higher than what the cylinder's column load, You should be fine.
How to measure a Hydraulic Cylinder
Here's an instructional video on how to measure and determine which type and size cylinder you will need.
Fell free to reach out if you have any questions.
JOHN DEERE Z997R LOT IDENTIFIER 227 (A53084)
JOHN DEERE Z997R...
2016 FORD EXPLORER (A51406)
2016 FORD EXPLORER...
2014 Nissan Pathfinder SUV (A51694)
2014 Nissan...
2007 Ford Crown Victoria Sedan (A51694)
2007 Ford Crown...
Plasmarc PM150 Plasma Cutter (A51691)
Plasmarc PM150...
