Admit Your Failure! Mower off the 3-point but PTO still connected...
   / Admit Your Failure! Mower off the 3-point but PTO still connected... #1
Dan Hunter
Platinum Member
Enid, OK
2012 John Deere 3720 eHydro
Yep, I've dropped the mower and forgot to disconnect the PTO shaft 3 times. Today was the worst as I'd just pulled it apart and cleaned/lubed both tubes only to drag the end in the dirt. Wiped it off on my shirt and moved on. I blame the 100 F temperature.
   / Admit Your Failure! Mower off the 3-point but PTO still connected... #2
Must have been a really serious reason to be mowing at 100F.
Nobody hurt - nothing damaged - I'll bet you won't forget again.
"I'll bet you won't forget again."
Sure I will.
   / Admit Your Failure! Mower off the 3-point but PTO still connected... #5
At least you didn't back up and bend the shaft.
   / Admit Your Failure! Mower off the 3-point but PTO still connected... #6
I’d rather pull the PTO shaft apart in 2 pieces than drive away with 7pin trailer plug for the tail lights or hydraulic lines still connected. That can cause damage.
   / Admit Your Failure! Mower off the 3-point but PTO still connected... #7
Unlatched the Euro hooks but forgot to lower the arms so it would actually unhook from the lower pins of the implement... Multiple times. Worse one was with the tiller, which had the stand down, so you can imagine what happened to it. 🤦
   / Admit Your Failure! Mower off the 3-point but PTO still connected... #8
I haven't pulled off with the pto shaft connected, but at least once I started to drive off with hydraulic lines attached. Fortunately I am always looking back and noticed the lines moving.
   / Admit Your Failure! Mower off the 3-point but PTO still connected... #9
Not mowing, but if it helps you feel better... I've been working in the shop the last three days re-wiring and replacing lights with high-bay LEDS.... 6 freaking trips to Home Depot in 2 days... except for the first all of them have been because I either bought the wrong item (as ex. 12-3 Romex instead of 12-2) or plain forgot something I intended to purchase (leaving a purchased j-box at the checkout counter).... the heat and humidity are no joke.
   / Admit Your Failure! Mower off the 3-point but PTO still connected... #10
Forgot to close the tractor cab door while pulling into the barn.
Boy that door exploding sounded like a bomb!
2015 CASE CX300C EXCAVATOR (A52707)
2015 CASE CX300C...
2017 FORD F-550(INOPERABLE) (A55745)
2017 FORD...
2020 INTERNATIONAL LT625 (A52472)
2020 INTERNATIONAL...
CAT P6000 FORKLIFT (A55745)
CAT P6000 FORKLIFT...
Wooden Rocking Chair (A55853)
Wooden Rocking...
