adjustment of 3pt cat 1 hitch
   / adjustment of 3pt cat 1 hitch #1
ewcjrc
marysville, ohio
kubota
I am having trouble getting the hitch center so that I can install the top pin. Don't know which bar to adjust to accomplish this ?? Any help ?? THE TOP LINK IS ABOUT 2" TO THE LEFT, SO i CAN'T INSTALL PIN. dON'T KNOW WHICH BAR TO ADJUST
   / adjustment of 3pt cat 1 hitch #2
You might want to mention what kind of implement you are trying to attach and which model Kubota tractor you have.
   / adjustment of 3pt cat 1 hitch #3
I don't understand the problem..Installing the top link pin onto an implement is the only easy part about hooking up a 3pt hitch. There is nothing to center. Just adjust the top link length in or out to match the hole on the implement and shove in the pin.. I am guessing that this is NOT what you are trying to describe or you would not be having trouble with it. Please try again on the description of the trouble you are having. Of course a picture would be worth, oh lets say 1000 words?:) Sorry to not be more helpful.
James K0UA
tHE TOP LINK IS OFF BY ABOUGHT 2" TO LINE UP I should mention, I'm using a quick hitch, and it doesn't line up top linik, by about 2 to the left.
   / adjustment of 3pt cat 1 hitch #6
For some implements such as a tiller that has tilted back too far you may need to pull forward slowly a few inches to get the top mast on the implement in position. Other implements such as a landscape rake or rearblade may require lifting with the lower arms to allow you to connect the toplink.
   / adjustment of 3pt cat 1 hitch #7
tHE TOP LINK IS OFF BY ABOUGHT 2" TO LINE UP!
No need to get cranky... Top links have "swiveling" eyes so it can move freely left to right. Front to back, follow what k0ua said or what jenkinsph said. All I can say is grab the toplink and pull it over two inches to line up.
   / adjustment of 3pt cat 1 hitch #8
You may try lifting the implment using the lift arm pins only, maybe 4 or 5 inches and then lower it back down. Sometimes this will help center the implement.
If you've got the main lift arm pins attached to the implement it almost has to be centered on the top link.
What type of implement are you trying to attach?
   / adjustment of 3pt cat 1 hitch #9
I'll try a translation. The guy is using a quick hitch and it is canted one way or the other so the top link attachment point doesn't line up with the implement's attachment point.
A guess is that the implement is tweaked out of alignment so the lower arms of the QH hook up but the top link won't. The implement doesn't have a perfect "A" configuration like the QH does.
My advice would be to take off the quick hitch and hook up the implement directly to the tractor's OEM quick hitch as described in many of the posts above.
   / adjustment of 3pt cat 1 hitch #10
Post up pictures of what your doing.
I am sure it can be solved much easier that way.
2018 MACK CHU613 PINNACLE DAY CAB (A53843)
2018 MACK CHU613...
Hyster H225E Forklift (A47477)
Hyster H225E...
CHERRY PICKER AND TRANSMISSION JACK (A53843)
CHERRY PICKER AND...
2016 JLG 3248RS 32ft Electric Scissor Lift (A50322)
2016 JLG 3248RS...
2019 INTERNATIONAL LT625 TANDEM AXLE SLEEPER (A54313)
2019 INTERNATIONAL...
2007 KUBOTA M9540 TRACTOR (A53843)
2007 KUBOTA M9540...
