Adjustment for BX2660 cruise control?
   / Adjustment for BX2660 cruise control? #1
nepa
Forest City, PA
Mitsubishi 180D, Jinma 284 sold, Kubota BX2660, IH Cub, Case 580CK, Minneapolis Moline 4 Star (sold), TYM 574, Furukawa FX-040
I cut about 2 acres around my house with my BX2660 and appreciate having cruise control but, when I set it, my ground speed drops perhaps 15% after I take my foot off of the speed pedal. Is there an adjustment that can be made to keep the tractor going the speed I would like to set it? Naturally, the engine speed does not change. Thanks.
   / Adjustment for BX2660 cruise control? #2
I found the same problem with the new BX I have. What I have found is to speed up a little more than you want, then set it and it will drop to where you want. Dont really know if there is an adjustment for it, but its not really a big problem for me. My biggest worry, is hitting a bump.....falling off because I didnt use the seat belt....and watching my new toy going across the yard and me in pursuit....then it hitting a tree and stopping....LOL.
   / Adjustment for BX2660 cruise control? #3
My two Kubotas are older models but both have that same mechanical cruise mechanism and they both do the same thing. They are evidently not anything more than some kind of pretty basic linkage that locks the HST pedal setting. When I want to set the cruise, it's always a hit or miss attempt to get it moving enough faster that it will settle down to the desired speed as the cruise is set. Strangely enough, I seldom use the cruise.
   / Adjustment for BX2660 cruise control? #4
Yup...my BX25D does the same...I just take it as a cue to slow down and smell the roses as I am mowing. :D
No time to smell any roses. I floor the hydro and get disgusted that my speed drops 15% when I lock the cruise.
   / Adjustment for BX2660 cruise control? #6
I could never mow my property at those speeds...too bumpy! I did, however, step on the pedal yesterday to see how fast it was and it really took off! :laughing:
   / Adjustment for BX2660 cruise control? #7
Are these newer tractors the same as mine from about 2004? The cruise is implemented by pushing 2 saw tooth cams together. The 15% drop that I feel is from the teeth locking together.
   / Adjustment for BX2660 cruise control? #8
Sounds like you need to sell the BX and get a Deere with the E Hydro. Otherwise you will have to live the sector lock cruise control.
David
2023 JACTO ARBUS-1000 LOT NUMBER 69 (A53084)
2023 JACTO...
2012 JOHN DEERE 13-INCH REAR WHEEL SPACER FOR 10 BOLT HUB (A53472)
2012 JOHN DEERE...
2009 Freightliner M2 106 MedTec Ambulance (A51692)
2009 Freightliner...
JOHN DEERE 1725 CCS LOT NUMBER 29 (A53084)
JOHN DEERE 1725...
2008 Ford F-550 Flatbed Truck (A52377)
2008 Ford F-550...
