Pat's Easy Change Adjustment bolt size on Pat's Easy Change and a short introduction for a new member
   / Adjustment bolt size on Pat's Easy Change and a short introduction for a new member #21
As you consider using a better fastener, realize that engineers 'May' have specified a softer one so it becomes the shear point and thus cheaper and easier to replace than the next weakest link.
Not saying that what you are doing is wrong but rather something to think about what will break if the bolt does not. Best of luck.
Those 8 bolts are all in compression when adjusted correctly. Not even that much compression if the jamb nuts are used properly. If fact, other than flopping around , no harm would come if they were removed. (other than "E-Z would not be a good description of the implement attachment process ;-)
The main pin takes the load.
   / Adjustment bolt size on Pat's Easy Change and a short introduction for a new member #22
The Pat's are apparently all shipped with grade 2 bolts.
I changed mine to grade 5 as suggested above.
Grade 5 bolts are less likely to fail, and are still easy enough to remove if broken.
I would not use grade 8 bolts for this application.
   / Adjustment bolt size on Pat's Easy Change and a short introduction for a new member #23
Not doubting anyone or any application specifically. Some lurkers or future posters may look at this and apply liberally to everything they find. Just bringing up the all too common phenomenon of unintended consequences. Carry on.
   / Adjustment bolt size on Pat's Easy Change and a short introduction for a new member #24
Can't fix stupid!
   / Adjustment bolt size on Pat's Easy Change and a short introduction for a new member #26
   / Adjustment bolt size on Pat's Easy Change and a short introduction for a new member #28
   / Adjustment bolt size on Pat's Easy Change and a short introduction for a new member #29
Have used my Pats system for 5 years with no issue from the bolts. Also havnt adjusted them since the install. You might not have a problem using what it comes with.
   / Adjustment bolt size on Pat's Easy Change and a short introduction for a new member #30
Been using these for 3 years and don’t understand the issue with the original bolts. So what if they mushroom a bit. You can still back them out enough to remove the hitch. If they get damaged they’re easy to cut or drill out, and it’s unlikely that the grade 2 will damage or gall the threads in the hitch if you try back out a mushroomed or damaged bolt.
But if grade 5 or 8 makes you feel more secure go for it.
2016 Ram 4500 Chassis Ambulance (A59230)
2016 Ram 4500...
2024 CATERPILLAR 255 SKID STEER (A52709)
2024 CATERPILLAR...
2012 JACK COUNTY TANK 130 BBL STEEL (A58214)
2012 JACK COUNTY...
500BBL WHEELED FRAC TANK (A58214)
500BBL WHEELED...
NEW HOLLAND 706 30 INCH 3PT DIRT SCOOP (A55315)
NEW HOLLAND 706 30...
2006 John Deere 120C Hydraulic Excavator (A56857)
2006 John Deere...
