Adjusting the Landrake
   / Adjusting the Landrake #1
Mike058
Key Peninsula, Wa
Kioti CK3510SE
I want to use the landrake to remove rocks from the surface, but it likes to dig in and pull up soil too. Is it possible to just skim the surface? Or am I asking too much? Any advice on what to try to make it less aggressive?
   / Adjusting the Landrake #2
Guide Wheels
Thanks. I do have guide wheels, but must not be using them correctly, or there's something else I need to adjust.
   / Adjusting the Landrake #4
If your landrake has two or more holes for your top link, use the lowest hole to the ground. That angle will give you the best angle to glide over the ground.
Don’t get me wrong, it will still dig in.
You will have to get good on the up/down lever and be active on it. When your tractor goes uphill, raise the rake. When it goes down hill lower the rake. It is very busy as a tractor driver using a rake, but it is better than doing it by hand.
I'm lucky I have 150' of path I can practice on that nobody can see :)
   / Adjusting the Landrake #6
I suspect some combination of gauge wheel and top link setting is going to get you what you need. I would probably shorten your top link drastically and see what effect it has. But id probably only do that AFTER determining if gauge wheel settings alone wouldn't accomplish it.
   / Adjusting the Landrake #7
Take the gauge wheels off, then turn the Landscape Rake around backwards. It won't dig in with the tine tips oriented to the rear.
   / Adjusting the Landrake #8
Wingfield Framed/Lift Chain Harrow Adjustment
CREDIT: - pmbutter - March 18, 2019
"There is a lot of contradictory information about which hole to use for the inboard end of the top link.
The top hole gives the least elevation change of the tail wheel, but better maintains parallelism with the ground.
An earth turning plow ought to be in one of the upper holes, so it remains at a proper working angle, regardless of its depth.
The bottom hole provides the greatest elevation change of the "tail wheel" of my "implement", but it also the greatest angular change relative to the plane of the ground.
The bottom hole is best for something like a landscape rake where you might want to lift it up and out of the way, perhaps with a little more angle so trash drops off the tines."
The bottom hole is the position of choice for a Subsoiler, an implement which often has issues with penetrating sufficiently deep and, when raised, having enough clearance to clear the dirt completely.
RELEVENT VIDEO:
----- 0 -----​
From continued reading I speculate that a Landscape Rake might provide a similar usefulness and take up less space. Have never used either so have no idea which would be better for my use. I have the land decently level with the box blade, but don't know which of these two tools are optimal for final leveling before the grass seed is put down.
You will probably prefer the Chain Harrow, which is flexible and the mat suspended, therefore mat follows the contour of the land closely, even as the TPH moves up and down. Due to mat design Chain Harrows do not dig in nor hang up on stumps or roots in the soil.
A rigid Landscape Rake moves up and down with the oscillation of the Three Point Hitch as the tractor wheels encounter uneven ground individually. Even with gauge wheels this is a problem. The Landscape Rake is more for grading when you want to move dirt or gravel to fill low spots, though move less dirt than a Box Blade. ( A heavy Landscape Rake is functionally 1/3 of the way to a rear/angle blade.)
If your dirt contains a lot of 2" to 4" surface rocks, which a Landscape Rake will windrow for removal, it would influence my recommendation an increment toward the rake over the harrow.
I owned an excellent ETA Landscape Rake with gauge wheels but sold it because I used it infrequently in my woodlands trail maintenance. I use the Chain Harrow regularly.
I have not priced ETA Landscape Rakes with gauge wheels in the last two years but I speculate they are twice as expensive as a framed/lift Chain Harrow. Light, cheap Landscape Rakes are practically useless.
You have not revealed how much space you want to smooth. Have you considered hiring four High Schoolers to power four bow rakes under close supervision?
   / Adjusting the Landrake #9
The Forest I work on maintains a couple of thousand miles of dirt roads. We have two rock rakes which are towed behind the service truck, and follow the Road Graders (Cat 16s) on the roads as they reshape them.
They are trailers and the rake portion adjusts directly up and down. They set the tines to go about 1/2-inch.
In practice the Grader re-fluffs the top 4-6 inches, and reshapes the prism. The rock rake comes after the blade and rolls the larger (rock 2-inch plus), off into the ditch. Then depending on the depth and condition of the topping gravels, we may add more topping gravel to the wear surface, and reshape again. Finally the roller comes behind and recompacts the surface.
The key is to get deep enough to get the rocks loose in the early passes, then decrease the depth the tines penetrate, skew the angle to about 30-degrees, and move the rocks to the side. The tines will bounce them across the road. But, they don’t do a good job of carrying them forward.
Basically, you want to fluff, then use progressively shallower passes to get the rock to the surface, and then skew the rake, and roll them off the side. To get the 4-inch plus rocks out of the top 2-inches you’ll have to penetrate 6-inches. Then make progressively shallower passes to bring them to the surface, before shewing the rake to roll them off
My place is a prehistoric gravel bar from when the river was historically, about two hundred feet higher than it is now, extremely rocky, with a lot of 4-inch plus material. I bought A rock bucket for the FEL to get down into it about a foot, and dig out the 2.5-inch plus material, as that, or building a top surface using a couple of hundred yard of in haul, is the only way to ever get a smooth surface without protruding rock in roadway and parking areas.
2013 Freightliner CASCADIA DAY CAB (A59575)
2013 Freightliner...
Unused 2025 CFG Industrial QH12R Mini Excavator (A59228)
Unused 2025 CFG...
2014 International Derrick Digger Truck (A55973)
2014 International...
HYDRAULIC THUMB CLAMP FOR MINI EXCAVATOR (A58214)
HYDRAULIC THUMB...
2010 MULTIQUIP 25KW GENERATOR (A55745)
2010 MULTIQUIP...
excavator trenching bucket- one bucket per lot (A56436)
excavator...
