Adjusting Rear PTO
/ Adjusting Rear PTO #1
BrandonEvans
Pittsburgh, Pa
John Deere 4200
Hello,
Lately I have heard a lite clicking coming from the rear of my tractor (4200). Found it was the rear PTO partially engaging. If I press down on the yellow PTO lever I can get the noise to stop. The PTO shaft does spin while the tractor is running without a load. With the brush hog on it mostly stops the movement.
Is there an adjustment knob or screw for this. It seems like it just need to turn it back a bit.
Thanks in advance.
Brandon Evans
Cranberry, Pa
4200, 420FEL, 60" MMM, 5' BH
/ Adjusting Rear PTO #2
Brandon,
I'm not familiar with your model tractor, but, on the ones I've had with a mechanical PTO lever, there was always some adjustment on the linkage. See if you can trace it out, and see if there isn't a threaded connecter on either end, that you can adjust.
Usually, the circulation of the oil inside the tranny will make the PTO shaft turn if there is no load on it. If it is moving while not engaged and you have a load of any kind on it, you need to have it checked, it may not be releasing completely, and could result in accelarated wear, as well as being dangerous.
I'm sure someone familiar with your model will eventually chime in. You could also call the service manager at your dealer. They have always tried their best to answer my questions, even the ones that they have to put the phone down first cause their laughing.
Good luck,
DT
2013 Honda Pilot AWD SUV (A61574)
2013 Honda Pilot...
UNUSED WOLVERINE HYD SCREENING BUCKET (A64281)
UNUSED WOLVERINE...
2015 Ford F-550 Crew Cab Flatbed Truck with Liftgate (A61573)
2015 Ford F-550...
2020 VOLVO VNL840 MIDROOF 6X4 T/A SLEEPER TRUCK TRACTOR (A59912)
2020 VOLVO VNL840...
Hydraulic Auger Bits Mini Skid Steer Attachment (A61572)
Hydraulic Auger...
2017 Dodge Charger Sedan (A61574)
2017 Dodge Charger...
