Adjusting position and draft control linkage on MF 165.
   / Adjusting position and draft control linkage on MF 165. #1
JRanch
Oklahoma City, OK
Massey Ferguson 165
I have posted a couple of threads concerning the 3pt on my MF165. Several of you have helped me tremendously to get this thing up and running. I have been successful in getting the 3pt to operate, however, when the 3pt reaches the top, it forces the diverter valve handle wants to pop back to neutral. It almost seems that there is an overpressurization issue. Is there an adjustment that I can make to the linkage that will correct this. I do not have the I&T shop manual. I have read other posts referencing this adjustment. Is there anybody that can help with this?
Thank you
   / Adjusting position and draft control linkage on MF 165. #2
Have you tried to adjust your max lift height at your lift lever? Should always be able to grab your 3-point links and be able to raise them several inches by hand.
Im really trying not to sound stupid here.....when you say adjust max lift height at the lift lever, how exactly is that done?
2015 Ford F-350 Dump Truck (A51692)
2015 Ford F-350...
2020 Toro Pro Sweep Vacuum (A55758)
2020 Toro Pro...
2011 GALYEAN 130BBL VAC TRAILER (A52472)
2011 GALYEAN...
SCAN FOR HAULING AND FINANCING INFORMATION (A54757)
SCAN FOR HAULING...
2022 John Deere 1023E MFWD Compact Utility Tractor with 120R Front Loader (A55302)
2022 John Deere...
