Adjusting position and draft control linkage on MF 165.
   / Adjusting position and draft control linkage on MF 165. #1
JRanch
Oklahoma City, OK
Massey Ferguson 165
I have posted a couple of threads concerning the 3pt on my MF165. Several of you have helped me tremendously to get this thing up and running. I have been successful in getting the 3pt to operate, however, when the 3pt reaches the top, it forces the diverter valve handle wants to pop back to neutral. It almost seems that there is an overpressurization issue. Is there an adjustment that I can make to the linkage that will correct this. I do not have the I&T shop manual. I have read other posts referencing this adjustment. Is there anybody that can help with this?
Thank you
   / Adjusting position and draft control linkage on MF 165. #2
Have you tried to adjust your max lift height at your lift lever? Should always be able to grab your 3-point links and be able to raise them several inches by hand.
Im really trying not to sound stupid here.....when you say adjust max lift height at the lift lever, how exactly is that done?
2016 Chrysler 200 Sedan (A50324)
2016 Chrysler 200...
2023 Case IH 4412F 12 Row 30 In. Row Spacing Folding Corn Head (A50657)
2023 Case IH 4412F...
2007 Amkus Rescue System (A50322)
2007 Amkus Rescue...
2016 Poulan Pro PP19A42 42in. Riding Mower (A49346)
2016 Poulan Pro...
2010 Keystone Cougar 5th Wheel T/A Travel Trailer (A48082)
2010 Keystone...
2000 CATERPILLAR 140H MOTOR GRADER (A51406)
2000 CATERPILLAR...
