3-Point Hitch Adjusting Pat's EZ Change
   / Adjusting Pat's EZ Change #11
Thanks qwdixon and johnthomas, I think I'll just stop thinking about it and continue mowing.
I think you'll be doing the right thing.
   / Adjusting Pat's EZ Change #12
I see the slight tilt you are mentioning, like others have said it really shouldnt be an issue unless you are havin git fall off in a odd way. From my point of view, when it tilts like that, the turn buckles needs to be tightened up so it will go more verticle then the tilt the way it is now. I also suspect you might not be able to do the turnbuckles since you probably have a pin type instead of bolt turnbuckles. is this correct ?
   / Adjusting Pat's EZ Change #13
Anybody else using Pat's the same JohnThomas did? Sorry for the double post.
   / Adjusting Pat's EZ Change #14
Anybody else using Pat's the same JohnThomas did? Opinions would be nice. Seems logical the hitch should ride with the ball, no?
(10) 28' Continuous Fencing Panels (A50515)
(10) 28'...
2013 TIGERCAT 720E WHEEL FELLER BUNCHER (A51242)
2013 TIGERCAT 720E...
2010 CATERPILLAR CM1210106 ROUGH TERRAIN FORKLIFT (A51242)
2010 CATERPILLAR...
2019 INTERNATIONAL LT625 TANDEM AXLE SLEEPER (A52577)
2019 INTERNATIONAL...
1997 Wells Cargo Enclosed S/A Trailer (A50324)
1997 Wells Cargo...
48 Inch Fork Attachment (A50322)
48 Inch Fork...
