Adjusting JX95 pto cable
/ Adjusting JX95 pto cable #1
L.Spooner
JX95
Hi I'm not sure how to adjust that pto cable. Does that cable need to come off? I see what looks like a clip on the the transmission side of the cable but I don't want to mess it up if I don't have to. I'm also reading about plastic at the hand lever end - should I just take the cover off and check that? should I lube it? any help thanks much. it's a 2003 2WD if it matters. I got it used and didn't get a book.
/ Adjusting JX95 pto cable #2
Pictures might help. Not sure what you mean by a cable. My pto shaft has a small chain that helps suspend it, but it is not a necessary part.
I wouldn't remove anything unless you are 100% sure it should be removed.
cool thanks I'll try to get a picture in a day or two.....it's a couple hours away right now :)
(2) Planter Boxes (A66408)
(2) Planter Boxes...
3ft Teakwood Cowboy (A65583)
3ft Teakwood...
UNUSED SDLANCH SDL2030GT-20' X 30' PREMIUM HEAVY (A64281)
UNUSED SDLANCH...
2000 Yale GLC030A 2,500lb Propane Foklift (A61572)
2000 Yale GLC030A...
2016 Hino 195h Truck, VIN # JHHSPM2H9GK001609 (A65563)
2016 Hino 195h...
Caterpillar 70in Loader Forks and Frame Attachment (A61572)
Caterpillar 70in...
