Adjusting hydraulic pressure relief valves on TYM 454 or other.
   / Adjusting hydraulic pressure relief valves on TYM 454 or other. #41
Hmm, keep feeling like I'm blind or stupid, lol but I dont see anything there. Must be completely different chasis or something.
Maybe as mine is a lm46.. Yours is a 35 or 36 right? They have one at Cabelas. When I go back to pick my tractor up I will look at theirs and see if I can locate it and will also ask the mechanic where it is. I don't know when it will be when they get my part in though. I told them if it was more than a few months I will come get the tractor and bring it back when the part comes in.
   / Adjusting hydraulic pressure relief valves on TYM 454 or other. #43
Yes sir, mine is the 36. That would be great. Thanks
   / Adjusting hydraulic pressure relief valves on TYM 454 or other. #44
No those caps are standard hydraulic blockage plugs.. they often make valves with several holes to accommodate different hose input angles..
   / Adjusting hydraulic pressure relief valves on TYM 454 or other. #45
I'm guessing your prv valve is located somewhere else.. probably because of transmission difference.. or the year..
   / Adjusting hydraulic pressure relief valves on TYM 454 or other. #46
Not sure, maybe the hst to shuttle but cant see a year making a difference, never know though.
   / Adjusting hydraulic pressure relief valves on TYM 454 or other. #48
Yes just took a picture of mine. It's where you have a dead end plug on yours.. maybe another location on that valve or another valve on your tractor.
   / Adjusting hydraulic pressure relief valves on TYM 454 or other. #49
   / Adjusting hydraulic pressure relief valves on TYM 454 or other. #50
Hmm, yep definitely not there on mine.
Thanks for pic, when the dam rain stops I'll have to crawl under again with flashlight.
2008 Volkswagen Passat Sedan (A51694)
2008 Volkswagen...
2013 Dodge Charger Sedan (A51694)
2013 Dodge Charger...
2008 KZ Sportsman Police Bunk 5th Wheel Tri-Axle Travel Trailer (A51694)
2008 KZ Sportsman...
JOHN DEERE CP 770 (A53084)
JOHN DEERE CP 770...
2022 John Deere X9 1100 Combine, (A53342)
2022 John Deere X9...
