Adjusting hst pedal-B3350 HSDC
   / Adjusting hst pedal-B3350 HSDC #11
Anybody? Bueller? Bueller? I've lubed everything I can find that moves wiggles or slides. The neutral safety switch (that prevents tractor start) had moved in it's slot outboard so the plunger wasn't engaging and the tractor wouldn't start. The 22mm nuts were a devil to get to, long pliers or make a thin 22 mm crowsfoot wrench, course that doesn't stop the forward creep.
I gave up fiddling around and now I just live with it. Use neutral a lot
   / Adjusting hst pedal-B3350 HSDC #14
Had the backhoe on, so put it in 2 wheel drive and lifted it up with loader and stabilizers. Neutral is pretty close to right (I didn't adjust it) as the wheels stopped some of the time or after tapping the reverse pedal. So I'll lube every thing I can find that moves once again.
2007 Western Star 4900 SA Tri-Axle Wet Kit Day Cab Truck Tractor (A56858)
2007 Western Star...
ONAN 100DCDB GEN SET (A52708)
ONAN 100DCDB GEN...
Steel Storage Cabinet w/Contents, 67" W x 24" D x 96" H (A59076)
Steel Storage...
R.F. Macdonald Co. Centrifugal Pump 3" x 4" (A59225)
R.F. Macdonald Co...
2022 Kubota U35-4 Mini Excavator (A57148)
2022 Kubota U35-4...
2001 Dorsey 48ft Flatbed T/A Trailer (A56857)
2001 Dorsey 48ft...
