Adjusting Brakes
   / Adjusting Brakes #1
Chris611
I am in the process of installing new brake plate assemblies on my 2008 LoadMax 14k gooseneck. It has AL-KO axles. I bought AL-KO 2" x 12" replacement brake plate assemblies from Southwest Wheel for all 4 locations. Then install has went pretty well. When I look at the instructions online for the brake assembly, they say to tighten the shoes until the wheels don't rotate, then back them off until the tire will rotate 3/4 of a revolution. My question is what does that exactly mean? So if it give it a "Price is Right" wheel spin, does it stop at 3/4" rotation? Do I give it a gentle push and it should stop at 3/4 rotation?
Any help would be great.
Chris
   / Adjusting Brakes #2
Yes. I adjust till I can not rotate then back them off till just a slight drag so they wear in.
You must adjust to lock up first to center everything up in the drum.
Chris
   / Adjusting Brakes #3
I have found it is usually 5-10 clicks back from full tight. Chris is right, you need to tighten them all the way up first to center the shoes. The 3/4 turn thing is a bit subjective in my opinion. I try to keep similar drag on all the drums when I adjust them too.
Brian
Case IH Patriot 3250 (A50123)
Case IH Patriot...
2025 K0720 UNUSED Metal Farm Driveway Gate Set (A53117)
2025 K0720 UNUSED...
2015 Big Tex 70PI 15ft Pipe Top T/A Utility Trailer (A50322)
2015 Big Tex 70PI...
2013 Big Tex 16GP-20 Gooseneck Trailer (A53117)
2013 Big Tex...
2008 KZ Sportsman Police Bunk 5th Wheel Tri-Axle Travel Trailer (A51694)
2008 KZ Sportsman...
