Tig
Elite Member
I just added rear remotes and TnT to my B7100 and I need to set the bypass on the spool valve. The tractor hydraulics are 1700 psi. The spool valve bypass is adjustable and factory set to 2100 psi. What should the bypass be set to? 1700psi?
Where should I put the guage to measure? Can I put the guage on one of the TnT QDs creating a deadhead for test purposes? What is the correct procedure?
