Adjustable Rod Assy lift arm
   / Adjustable Rod Assy lift arm #1
Kc8ehd
Hinton Wv
LS XR4040C
Can anyone think of any cons to having adjustable lift arms on both sides (left and right)
   / Adjustable Rod Assy lift arm #2
As in top 'n tilt? That's what I have, hydraulic one side, crank on other. No negatives I can think of.
   / Adjustable Rod Assy lift arm #3
Cost is the only one I can think of.
$168 , Cost not bad , can't get angle I need on box blade tilting left without adjusting end bolts ,plenty of tilt to the right unless the bolts were adjusted for left tilt.
   / Adjustable Rod Assy lift arm #5
No cons that I'm aware of ---- I have adjustable lift rods on both sides. I found the second one on E-Bay.
   / Adjustable Rod Assy lift arm #6
If I was going to do it, I would probably buy a hydraulic tilt cylinder for the right side and move the factory manual leveling box to the left. That way you would only have to manually adjust the left ever so often but have on the fly adjustment on the other side.
Thinking the hydraulic is the way to to go , upon closer inspection replacing the fixed rod with a leveling would do very little to help , when extended its the same leanth as the fixed rod is now... , would someone please list what I need to convert to hydraulic cylinder ...(cylinder size , hoses , coupling
And are flow restrictors needed
   / Adjustable Rod Assy lift arm #8
Something sounds VERY wrong. The adjustable side link should be half way extended to be the same length as the fixed link. Collapse it to tilt down to the left, extend it to tilt down to the right. Are the pins in the same hole location in the lower clevis? Either both in the top or both in the bottom pin location?
Sorry for the side ways picture.
   / Adjustable Rod Assy lift arm #9
Your picture is not sideways when you click on it.
JOHN DEERE 608C LOT NUMBER 19 (A53084)
JOHN DEERE 608C...
2023 John Deere 410R Sprayer (A53342)
2023 John Deere...
City of Lakeland (A51691)
City of Lakeland...
2002 Mack DM690S Roll Off Truck, VIN # 1M2B209C32M028771 (A51572)
2002 Mack DM690S...
20307 (A51694)
20307 (A51694)
2005 Dodge Caravan Van (A51694)
2005 Dodge Caravan...
