adjust shfter lever
/ adjust shfter lever #1
mffarmall
Colorado
Farm Pro 2425, MF 50, JD B, Farmall Super MTA
When I shift into forward it slips out of gear. Items done.
Changed clutch, and adjusted
shifter arm pin broke and hole is larger on the knuckle. Put larger shaft into hole. With a little play.
Problem is that the shifter does not have enough forward movement to lock the gear in.
? If I adjust the shfter cable to make it tighter will it take in the play, so the shifter will be able to go into gear?
/ adjust shfter lever #2
not sure on these (never had mine off) but on most gear shifters there are stop bolts for forward and aft movement that stops the shifter from pushing the forks HARD into place this tops bent or worn shift forks or other issues as well..
Year: 2023 Make: Chevrolet Model: Tahoe Vehicle Type: Multipurpose Vehicle (MPV) Mileage: 44,433 (A64557)
Year: 2023 Make...
2025 Unused SDLGC80 60v Electric Golf Cart (A64194)
2025 Unused...
Woods 72" 3-Pt Rotary Mower (A66408)
Woods 72" 3-Pt...
New/Unused Wolverine 84in Quick Attach Smooth Bucket (A65583)
New/Unused...
2022 CATERPILLAR 950M WHEEL LOADER (A65053)
2022 CATERPILLAR...
2015 GMC Yukon XL Denali SUV (A64557)
2015 GMC Yukon XL...
