mffarmall
- Joined
- Sep 16, 2005
- Messages
- 417
- Location
- Colorado
- Tractor
- Farm Pro 2425, MF 50, JD B, Farmall Super MTA
When I shift into forward it slips out of gear. Items done.
Changed clutch, and adjusted
shifter arm pin broke and hole is larger on the knuckle. Put larger shaft into hole. With a little play.
Problem is that the shifter does not have enough forward movement to lock the gear in.
? If I adjust the shfter cable to make it tighter will it take in the play, so the shifter will be able to go into gear?
