Adjust parking brake latch (BX24)
   / Adjust parking brake latch (BX24) #1
RayCo
Veteran Member
Chester County, PA
Kubota BX24, Case 580 Super L
I've noticed that over the past few days that the parking brake on my BX24 will sometimes disengage between the time I park it and the next time I return to the tractor. It seems that the pedal is extra sensitive lately, and if a grasshopper hops onto the pedal, it's enough to make the pedal pop up now. Is there an adjustment for the linkage that holds that pedal down when you engage the parking brake?
   / Adjust parking brake latch (BX24) #2
Adjust the brake like the manual says. The "free play" is set and the brake will have a certain amount of "tension" when you set the lock. If it is not set correct, you will either have alot of tension, or like yours, not enough.
Deano
Thank you Deano. I guess checking the manual is a good idea, huh? :ashamed:
2013 MACK ELITE LEU613 GARBAGE TRUCK (A51406)
2013 MACK ELITE...
2014 D&P WELDING 16FT PRESSURE WASH TRAILER (A52472)
2014 D&P WELDING...
2020 Kia Soul (A52377)
2004 Ranger 195 VX Comanchee Bass Boat with Trailer (A51573)
2004 Ranger 195 VX...
2014 LAMAR TRAILER (A52472)
2014 LAMAR TRAILER...
2017 FREIGHTLINER M2 S/A SWEEPER TRUCK (A51406)
2017 FREIGHTLINER...
