Oil & Fuel Adjust idle speed on Ford 3000 (has Simms fuel injection pump)
   / Adjust idle speed on Ford 3000 (has Simms fuel injection pump) #1
rmorgan3000
Black Mountain, NC
Ford 3000 diesel
How is the idle speed and maximum no load speed adjusted on a 1971 Ford model 3000 tractor adjusted? This has a Simms fuel injection pump that has been refurbished. Rmorgan
   / Adjust idle speed on Ford 3000 (has Simms fuel injection pump) #2
Go to the hew New Holland Forum and post this. There are a couple of knowledgeable folks there who may be ale to help you. Generally speaking, you put the throttle in the idle position and
use a screw to set the lo idle stop. I'm not sure but I think it's the same with the high idle.
   / Adjust idle speed on Ford 3000 (has Simms fuel injection pump) #3
2014 MACK ELITE LEU613 GARBAGE TRUCK (A51243)
2014 MACK ELITE...
2015 SkyJack SJ86T 4x4 86ft Telescopic Boom Lift (A49461)
2015 SkyJack SJ86T...
71069 (A49346)
71069 (A49346)
4 BRIDGESTONE 11R24.5 (A50854)
4 BRIDGESTONE...
2016 Ram 1500 4x4 Crew Cab Pickup Truck (A49461)
2016 Ram 1500 4x4...
2020 KUBOTA RTV...
