Adequate wire size for ROPS lights
/ Adequate wire size for ROPS lights #1
5030tinkerer
Iowa
Kubota GL3830/GL5030
I am about to hook up some lights to my ROPS on my L5030. I have noted the green molex plug near the seat belt and see that it conveniently has 12V coming to it when the ignition is on. Question: can that little wire pair (looks like 16 or 18 gauge) handle four 55w lights? Any idea on where to get the mate to that plug or do most guys just get two male spade connectors and go from there?
/ Adequate wire size for ROPS lights #2
If you are going to use all four lights at once they will draw a little over 18 amps. Max rating for 16ga wire is 20-22 amps (depending on what chart you use). I'd use a 20 amp fused 14 ga wire going from the battery through a relay and then to the lights. Use the wire you found near the seat to energize the relay.
2022 EZ-GO ELITE...
Year: 2011 Make: Chevrolet Model: Express Vehicle Type: Van Mileage: 118,735 Plate: Body Type: 3 (A59230)
Year: 2011 Make...
2013 John Deere Hydraulic Grapple Tractor Attachment (A61572)
2013 John Deere...
Lot of 4 10-16.5NHS Skid Steer Wheels and Tires (A61572)
Lot of 4...
E-Z TRAIL 3400 SEED TENDER (A63291)
E-Z TRAIL 3400...
Hydraulic Auger Bits Mini Skid Steer Attachment (A61572)
Hydraulic Auger...
