Addon hydraulics for a old super dexta
   / Addon hydraulics for a old super dexta #1
Jesper
Fordson Super Dexta 1964
My old Fordson Super Dexta has a front loader with a tip bucket, I have to pull a cable to release it. I would like to add two way hydraulic cylinders for both the front loader and the bucket.
I see a solution where I disconnect the orginal hydraulics for the front loader and only use this for the lift arms. And then add a addon hydraulic pump for the front loader and bucket, and a controll valve.
Therefore my question is if anyone has a layout diagram and some parts advises to make this work?
Thank you for reading my post :)
   / Addon hydraulics for a old super dexta #2
You apparently have a mechanical dump bucket, not uncommon for the vintage. Are you presently controlling the loader lift with your 3-pt control lever? Is there a bolt-on plate just forward of your seat mount (which may be the auxilliary services control currently used for your loader)? If so, you may be able to install a dual spool control valve in it's place to provide the conrols you are looking for.
The solution you suggest is workable, but there may be another less costly solution.
Yes, I have a mechanical dump bucket. In front of my seet I have auxilliary services control and flow adjuster. I'm using the original control lever to control my front loader when switched to auxilliary.
Would there be a dual spool control valve that would be a straight bolt on?
   / Addon hydraulics for a old super dexta #4
cheap way is to get a suitable 2 spool valve and run it off the valve that is currently running hte laoder lift circuit.
soundguy
2013 Cadillac Escalade Luxury SUV (A50324)
2013 Cadillac...
1996 JLG Commander CM2033 20ft Electric Scissor Lift (A51691)
1996 JLG Commander...
2019 CATERPILLAR D6N LGP HIGH TRACK CRAWLER DOZER (A51246)
2019 CATERPILLAR...
2017 Ford Explorer AWD SUV (A50324)
2017 Ford Explorer...
1992 Effer 7600 2S Knuckleboom (A51691)
1992 Effer 7600 2S...
2017 Ford Escape SUV (A50324)
2017 Ford Escape...
