Additional Link
   / Additional Link #1
MChalkley
Elite Member
Eastern Virginia
EarthForce EF-5 mini-TLB (2001)
Muhammad - I was wondering if it would be a worthwhile change, when you roll out the new version of TBN, to turn the subject of a message, when viewed in flat mode, into a link to itself. My reason is this: In flat mode, the name of the sender message replied to becomes a link to the message itself, but there's no way to see the link (actually, the message number would be sufficient) in flat mode. If the subject of each message became a link to itself, you could just "mouse-over" the subject of the messages from the sender concerned and verify which one this message is a response to. Does that make any sense at all? Or should I try explaining it again... /w3tcompact/icons/wink.gif (As 2,000 virtual voices cry out at once: "No, No, No, anything but that!!!" /w3tcompact/icons/laugh.gif)
MarkC
   / Additional Link #2
Well, would it help to post the message numbers? I guess you want to clear up who is being replied to, right?
   / Additional Link #4
Yeah, I will see what i can do. /w3tcompact/icons/smile.gif
   / Additional Link
Muhammad - Did this feature get dropped, or is it in the next version? /w3tcompact/icons/smile.gif
   / Additional Link #7
I left it on the list along with the display of a user's tractor and location in the header ... I'll see if I can get to it with the minor changes I'm going to make today.
   / Additional Link
Muhammad - Thanks! I knew it was on one of your lists - just wasn't sure which one. /w3tcompact/icons/smile.gif
2011 Ford Fusion SE Sedan (A51694)
2011 Ford Fusion...
2024 JOHN DEERE 3039R LOT IDENTIFIER 55 (A53084)
2024 JOHN DEERE...
UNUSED JCT HYD TRENCHER (A51248)
UNUSED JCT HYD...
UNUSED MOWER KING 72" HYD BRUSH CUTTER (A51248)
UNUSED MOWER KING...
2007 Ingersoll Rand P185WJD Towable Diesel Air Compressor (A52377)
2007 Ingersoll...
