Additional Hydraulics
   / Additional Hydraulics #1
ch47dpilot
Enterprise Alabama
09 Kubota L3400
I have one other question on this topic. If I run a lower flow rate will I lose torque? My understanding is PSI creates torque and flow will affect RPM. The motors run about 10x faster than I need. Can I just reduce the flow from 6.3 to what ever I need and not loose torque? Assuming PSI can be maintained at 2000psi?
   / Additional Hydraulics #3
You're understanding is correct. You will loose some torque at slower flow rates because efficiency is reduced. 1/10 of rated flow is kind of extreme though. Its always better to run a motor close to its rated rpm. I expect there is a chart somewhere that would tell you what to expect out of that motor with reduced flow.
Kim
2000 PETERBILT 357 6X6 DAY CAB ROAD TRACTOR (A51406)
2000 PETERBILT 357...
2005 Isuzu NPR Venco VC516 Landscape Dump Truck (A53422)
2005 Isuzu NPR...
2015 Ford E-350 Cutaway Van (A52377)
2015 Ford E-350...
2005 International 4200 Texoma UC-301 Pier Drilling Truck (A52377)
2005 International...
Ford Super Duty Pickup Truck Bed (A51691)
Ford Super Duty...
CASE 580 (A47477)
CASE 580 (A47477)
