adding tach to kioti tractor
   / adding tach to kioti tractor #1
frank12345
I'AM LOOKING TO ADD A TACH TO MY TRACTOR DIESEL ENGINE WHAT KIND SHOULD I BUY AND WHERE DO I HOOK IT AND WHERE WOULD I FIND ONE THANKS
   / adding tach to kioti tractor #2
Install a tiny tach Look for the Commercial powered one model DTTNR
Several members here have it on their tractor and it works well for them.
$65.00 and requires a tranducer mounted "around" the fuel line.
   / adding tach to kioti tractor #3
The tiny tach works well, and comes with the transducer to clamp on one of the injector lines, just give them the diameter of the line and they'll send the unit and all the parts with instructions, it's really easy to install.
   / adding tach to kioti tractor #5
Is this the same Kioti that you drop down to 2500 rpm after startup? /forums/images/graemlins/confused.gif
Skil 5 speed Small Drill press (A53117)
Skil 5 speed Small...
Husky Crossbed Truck Tool Box (A51695)
Husky Crossbed...
2004 FORD F-650 SUPER DUTY DUMP TRUCK (A51406)
2004 FORD F-650...
2006 FREIGHTLINER CST120 (A53843)
2006 FREIGHTLINER...
2015 FORD-750 XL SUPER DUTY DUMP TRUCK (A51406)
2015 FORD-750 XL...
Valvoline 80/90 Gear Oil (A53117)
Valvoline 80/90...
