Adding Tach to a TO 30 Tractor
   / Adding Tach to a TO 30 Tractor #1
Lazy
Platinum Member
Missouri
ford 1920 w/fel and bh, case 470, allis chalmers B 1937, JD 450 track loader, Case vac, 3 cub cadets ford lgt 125, Kubota 2230/60 inch mower.1948 farmall cub 1953 farmall cub
Hi
We just purchased a TO 30 Ferguson Tractor and have thought about adding a tach/hour meter from northern tool Item # 160590. Has anyone installed one of these and if so how do you like it?
   / Adding Tach to a TO 30 Tractor #2
I didn't look the # you posted up.. but if it is the little electronic tach that uses an inductive pickup wire from a spark plug, and runs off a watch battery.. then yeah.. that's a common way to add a tach to a gasser with no provisions for a tach.
soundguy
   / Adding Tach to a TO 30 Tractor #3
I bought one of those mini tachs/ hour meters for my riding mower, and it does what I needed. It works fine for any engine that uses a governor, and is therefore supposed to operate at a nearly constant rpm. However, it is not suitable for any engine that is increasing or decreasing in speed rapidly, since the tach readout will not keep up with the rpm change. So, for instance, the tach would be useless for a stick shift automobile where you might use the tach for your shift points. When the rpm is changing rapidly, the lag between the actual engine rpm and the tach readout can be as long as 3 or 4 seconds. The nominal sampling frequency for the tach is 1 second, but there's a lot more going on here , and a stabilized reading takes much longer. I'm also a bit irritated that those mini tachs have an internal, non-replaceable battery that lasts for about 5 years, and then you have to buy a new tach. The whole circuit is potted in epoxy, so replacing the battery is mighty difficult. The tach I bought from Northern is adjustable for 2 and 4 cycle engines, and with a plug firing every revolution or every other revolution. Since the tach signal is from the spark plug wire, you'll need to get that right. ( Some 4 cycle engines fire the plug on every revolution, like a 2 cycle, but the firing on the exhaust cycle is not necessary.) Not all of those mini tachs are as adjustable, so be careful which one you buy.
   / Adding Tach to a TO 30 Tractor #4
I added 1 to one of my atv's . I don't know of a way to replace the batt. in the 1 I bought. Doesn't look like comes apart
2013 E-One 95FT Ladder Fire Truck (A51692)
2013 E-One 95FT...
2025 SDLANCH SDLGC80 UNUSED Electric Golf Cart (A53117)
2025 SDLANCH...
Michelin CARGOXBIB High Floatation Tires (SET OF 6) (A53473)
Michelin CARGOXBIB...
2016 E-Z Beever M12R Towable Brush Chipper (A51691)
2016 E-Z Beever...
2020 Westfield MKX 100-83 Auger with Swing Hopper (A53473)
2020 Westfield MKX...
2015 TROXEL KILL TRAILER (A53843)
2015 TROXEL KILL...
