Adding SCV to beyond beyond on JD 3038e
   / Adding SCV to beyond beyond on JD 3038e #11
Yes, it is designed to "divert" fluid from one circuit to another. You only have control (through a directional control valve-like the loader joystick) of one circuit at a time. It is operated by a simple ON-OFF switch (usually momentary).
The "true 3rd function" is completely independent and can operate a cylinder(s) all by itself through the use of a 3 position switch ON-OFF-ON
Clear as mud?;)
Thx, I think I understand now. Using the power beyond you can kurl the bucket and operate the grapple at the same time.
   / Adding SCV to beyond beyond on JD 3038e #12
Correct.
FORD F SERIES DUMP TRUCK (A52707)
FORD F SERIES DUMP...
2015 Peterbilt Dump Truck (A55973)
2015 Peterbilt...
2011 Toyota Camry Sedan (A56859)
2011 Toyota Camry...
Rooster Weathervane (A55853)
Rooster...
2007 DELTA GOOSENECK TRAILER (A58214)
2007 DELTA...
48x4 Mini Skid Trencher (A56436)
48x4 Mini Skid...
