Adding remotes to L4310
   / Adding remotes to L4310 #1
rymo
kubota l4310
I have a hydraulic valve by the front brake pedals next to the filter can I plumb into this to add remotes or do I have to get the block from kubota?
   / Adding remotes to L4310 #2
You talking about under the floor , do you have a front loader? If your talking about the control block under the floor and you have no loader, yes you can use the ports to run a control valve, you would need on with Power Beyond, to do it right, this block is were the loader valve would hook into the system.
2017 Rogator RG1300B Dry Fertilizer Applicator (A56438)
2017 Rogator...
SEMI AUTOMATIC QUICK CHANGE FOR MINI EXCAVATOR (A58214)
SEMI AUTOMATIC...
2014 FREIGHTLINER CASCADIA (A58214)
2014 FREIGHTLINER...
Honda EM3500S Portable Gasoline Generator (A59228)
Honda EM3500S...
KBH 25T Tender (A56438)
KBH 25T Tender...
Rotary SPOA9-200 Automotive Lift (A56857)
Rotary SPOA9-200...
