Adding rear remotes, what kind should I get?
   / Adding rear remotes, what kind should I get? #1
ranger danger
East of Hangtown Ca
Kubota M6060, MEB802 Generator
I'm having 2 Rear remote hydraulics added to my Kubota M6060. The one it came with is a float detent. Which type should I have for the other 2? I have a top cylinder which I thought could be used with a spring center, no need to float it. I'm thinking a second float. I have a snow plow/dozer blade and a tree and post puller that require hydraulics for now but I may add implements later like a down force for a post auger. Any suggestions are appreciated.
   / Adding rear remotes, what kind should I get? #2
I think you are on the right path. For the snow/dozer blade (depending on how the mount is) I would want the float for plowing snow and back dragging.
   / Adding rear remotes, what kind should I get? #3
I have float on my top cylinder for when I bush hog, it lets the front of the mower move up and down.
I have one remote with a detent for on position. I use that for things like a post pounder or log splitter where I'm on the ground with something that has it's own hydraulic control.
So of my 3 remotes, two have detent for float and one has detent for on. Having float doesn't hurt anything but might come in useful.
This is what the manual suggests. 2 self canceling and 1 float.
1. Double acting valve with detents and self cancelling
2. Double acting valve with float option
3. Double acting valve with detents and self cancelling
2019 INTERNATIONAL LT625 TANDEM AXLE SLEEPER (A51222)
2019 INTERNATIONAL...
New Swict 60" Skidloader Bucket (A50774)
New Swict 60"...
Agway AccumuL8 Grabber (A50515)
Agway AccumuL8...
Danuser 3 pt Post Hole Digger (A50515)
Danuser 3 pt Post...
2025 12V Diesel Pump and Hose (A50324)
2025 12V Diesel...
2013 Nissan Sentra Sedan (A50324)
2013 Nissan Sentra...
