Adding Rear Remotes for Hydraaulic Flail Mulcher
/ Adding Rear Remotes for Hydraaulic Flail Mulcher #1
Kurmond Kubota
Kurmond, New South Wales
Kubota L3010
Hi All
I am new at playing with Tractors...
I have a Kubota L3010 tractor with no Hydraulic setup on it at the moment.I am trying to purchase a Flail Mower with Hydraulic offset as I need to get into tight places hence the offset.
I need to start from scratched ,I have the hydraulics on the right side as standard for the Kubota. The Manual says that you can tap into the Hydraulics there but I don't know what other things I need to set up the rear remotes.
In addition I will be adding a FEL in the near future (sorry for the late inclusion )
Thanks in advance
Kumond Kubota
/ Adding Rear Remotes for Hydraaulic Flail Mulcher #2
On the hyd block, you have a pressure out port and a PB return port from the valve PB port.
Your remote valve should also have these ports if you add the PB adapter.
Just connect the P from hyd blk to the IN on the remote valve.
Connect the PB hose back to the hyd blk.
Connect the OUT.return port to any return line.
There may be a lever you turn when using the ports.
In your current position, the flow is passing through the valve to the 3pt.
You might want to consider a two or three spool valve for T-N-T, or whatever attachments, maybe even float.
The flow is routed a little differently for a FEL.
/ Adding Rear Remotes for Hydraaulic Flail Mulcher #3
Iirc it's an open centre system . Keep that in mind when choosing valves and relief settings.
JOST FIFTH WHEEL PLATE (A64276)
JOST FIFTH WHEEL...
250 GALLON FUEL TANK (A64276)
250 GALLON FUEL...
2022 New Holland Boomer 45 (A64126)
2022 New Holland...
2004 Lincoln Navigator SUV (A61574)
2004 Lincoln...
2014 CATERPILLAR 938K WHEEL LOADER (A65053)
2014 CATERPILLAR...
FIRMAN H07553 GENERATOR (A64276)
FIRMAN H07553...
