Adding rear hydraulics to J2023
   / Adding rear hydraulics to J2023 #1
fhennigan
melder,la
ls j2023h
:confused2: I need to add rear hydraulics to a J2023. I know there's a kit out there, but the ports are taken up by the fel. Is there a way around this? Any help would be appreciated.
   / Adding rear hydraulics to J2023 #2
The kit would tap into the power beyond coming out of the loader valve before it gets to the three point hitch hydraulics.
Theoretically, you could install as many rear remotes as you like, but the first valves in the system always have priority.
The steering always gets first dibs on hydraulic flow, but it doesn’t really rob from the rest of the system. Then the loader valves, then rear remotes, and last is the three point.
Thanks,that helps a lot.
PALLET OF DRAINS / DRAIN GATES (A51244)
PALLET OF DRAINS /...
2015 JEEP PATRIOT (A51406)
2015 JEEP PATRIOT...
UNUSED TOPCAT QUICK ATTACH STUMP GRINDER (A51244)
UNUSED TOPCAT...
2019 TAKEUCHI TL8 SKID STEER (A51242)
2019 TAKEUCHI TL8...
2013 Ford E-350 Enclosed Service Van (A50323)
2013 Ford E-350...
2015 CATERPILLAR 326FL LONG REACH EXCAVATOR (A51242)
2015 CATERPILLAR...
