Adding quick attach plate to Bucket -HELP!
/ Adding quick attach plate to Bucket -HELP! #21
If you guys dont mind I am going to hijack your thread for a post rather than start a new thread and it sorta fits in with the subject matter.
I have a montana with a cab. I have noticed with the cab that I cant see the outside of my quick attach mount plate mounted to my tractor. This makes it a bit difficult to line up the attach plate with the bucket since there is almost now extra space for that to fit correctly. I usually wind up having one side against the edge of the bucket mounting bracket and cant get close enough to line it up. I dealt with this for the last three years with just minor annoyance. The other day I was putting my bucket back on and had this problem again. When I got the bucket on I pulled up to my work shop and put a piece of tape on the top of the bucket marking where the Tractor attaching plate fit on the bucket. ( The plate has two arms one on each side and they are about 5 inches wide, it is made to fit skid loader quick attach implements.) I then pulled the bucket back off took a handy can of silver spray paint and painted the area where the attach plate will sit. Now when I go to hook up to the bucked I can see exactly where the arms have to be. I will admit that I am somewhat challenged at some things but if anyone else has the same problem this might help you
/ Adding quick attach plate to Bucket -HELP! #22
BX24, You might want to find out if your bucket is made from AR steel. I am sure they are not mild steel. AR is expensive and hard to find in small pieces.
Bill
/ Adding quick attach plate to Bucket -HELP! #23
After doing mine w/ a plasma cutter and just cutting the welds, next time I would cut through the bucket , leaving two rectangular holes in the bucket where the original mounts were. This would also give more surface area to weld the plate on.
Alan
/ Adding quick attach plate to Bucket -HELP! #24
Alan
I guess I'm reserecting a old thread but its new to me so here goes.
I started on mine today and I'm almost ready to throw in the towel and add windows where the brackets are.
Just how deep are those filletts? I cut out the plug welds with a 1 3/8 hole saw.
/ Adding quick attach plate to Bucket -HELP! #25
Yea, a pretty old thread, but anyways.
I have used my plasma cutter many times to cut out old welds with good success. With the cutting tip laid back and off the metal, i will start the arc and move it into the metal. With the amps turned all the way up and moving pretty fast, you can blow the weld out of the seam without blowing thru the base metal. Takes a little grinding to clean it up and you might have a few pock marks or gouges here and there, but beats the heck out of zip wheels and grinders if your working with thicker metal.
/ Adding quick attach plate to Bucket -HELP! #26
I went in as deep as I could with zip wheels (6" was as large as I found locally) the gear case on the grinder and the pin bosses really limit the cutting depth but it still was not deep enough. I ended up using the torch to finish the job. I have since located 7" cutoff discs and a fresh one may have had the reach needed .
I had hoped to reuse my intact bracket but the extrication process rendered it more damaged than I hoped for so I cut it at the bend and welded it to a piece of sq tube.
/ Adding quick attach plate to Bucket -HELP! #27
Glad I was not the only one to have trouble with those welds.. If you are interested in my struggle, here it is.
James K0UA
2000 Yale GLC030A 2,500lb Propane Foklift (A61572)
2000 Yale GLC030A...
2013 Ford F550 Bucket Truck w/ Jib (A62613)
2013 Ford F550...
2014 FREIGHTLINER CASCADIA 113 S/A DAY CAB TRUCK TRACTOR (A59912)
2014 FREIGHTLINER...
UNVERFERTH 12R30" RIP STRIPPER (A63291)
UNVERFERTH 12R30"...
2023 New Holland CR10.90 Combine - 330 Engine Hours - 251 Separator Hours (A63688)
2023 New Holland...
4022CFL (A59228)
4022CFL (A59228)
