He only has a 5.2 GPM.
However prince makes a LSR-3060-3 valve that works like regen to speed up splitting times.
FUNCTION:
The Prince LSR-3060-3 log splitter valve features an extremely
fast “Rapid Extend” high speed mode. The LSR
has been specifically designed to reduce system costs by
allowing a single stage pump to be used in systems currently
using two stage (hi-low) pumps. When extra splitting
force is required, the LSR allows the user to manually shift
form high speed mode to high force mode. A “soft stop”
differentiates between high force and high speed modes.
Laboratory testing has not shown a significant difference
in working cycle times between single stage/rapid extend
systems and two stage systems. (Working cycle is the
average time between extending the cylinder to split the
first log and extending to split the next log after the split
wood has been removed and a new log has been placed
on the log splitter.)
Those PTO pumps also run about $470.[/QUOTE
Should I get the 540 rpm model or the one that increases the pto speed?
