adding power steering to 950
   / adding power steering to 950 #1
jacksdad
I am looking at buying a 950 2wd w/ FEL and approx. 1800 hrs. The tractor does not have power steering and i don't know if it can be added or if i should keep looking till i find it.
i will be using the tractor to bush hog and mow approx. 3 acres, maintain a medium sized veggie garden and, initially, move around 10-20 loads of fill to get my grading right (we are having a house built). It will also be used to maintain about a 160' driveway.
i thought about the 790 but it's considerably more expensive (i believe i can get the 950 for $6k) and probably not worth the money for power steering and 4wd. Our lot is very flat (maybe a 2-3' elevation change over 400 feet).
So can power steering be added? Is it expensive? Am I ok with 2wd?
Thanks for the help,
Erik
   / adding power steering to 950 #2
I have a 1984 JD 950 MFWD (4wd), FEL, and PS. I have seen a used power steering kit on ebay a couple times, but not lately. Not sure what it would take to actually add it on.
As far as the 2wd, that may be a problem in dirt work. I have ag tires, but my traction is not that great in 2wd, even with the diff lock. Significant difference in 4wd when trying to push into a pile of dirt to load the bucket. Now I will say that my rear tires appear to be the original and the rubber seems to have hardened and is pretty slick. I have new tires on the front and there is an obvious difference. That may be part of my problem.
thanks bb. i will watch out for a cheap kit.
i bought the tractor and love it already! entire thing was sandblasted, primed and repainted and looks great. i paid $6,500 and think i got a very fair - excellent deal. didn't steal it, but happy with the price.
do you know if the 950 will pull a 7' finish mower or should i stick with 6'?
thanks,
erik
   / adding power steering to 950 #4
Yeah. I really like my 950 also. Don't know about the finish mower. I run a 6' rotary cutter on mine and it cuts pretty tall and thick grass fine. I would think it would run a 7' finish mower OK for cutting short grass.
As a side note. The muffler on mine was loud and badly rusted and rattling inside. I let it go for several years, but replaced it last month. The result was a significant boost in HP!!. I guess it was restricting or otherwise messing up the exhaust flow. Made quite a bit of difference mowing tall grass.
2015 CATERPILLAR AP1055F ASPHALT PAVER (A51242)
2015 CATERPILLAR...
2012 FORD F-150 XLT (A50854)
2012 FORD F-150...
2021 John Deere 6130M 4WD Tractor w 620R Loader, Premium Cab, 250 Hours (A51039)
2021 John Deere...
CFG MH12RX Mini Excavator (A49461)
CFG MH12RX Mini...
Grady-White 17ft Fishing Boat with T/A Boat Trailer (A50324)
Grady-White 17ft...
Mahindra 26XL Tractor 4X4 Loader Backhoe (A51243)
Mahindra 26XL...
