adding Power beyond to tractor with SCV
   / adding Power beyond to tractor with SCV #1
meb9796
VA
JD 3720
I have a 2010 JD 3720 and recently purchased a used ARPS 728 backhoe attachment. I only have dual SCV on the rear (not sure of the correct name, but requires you to pull the lever to get Hyd fluid to flow). I can use the BH if I bunjie cord the lever in the up position, but obviously this isn't a good long term position. I need a power beyond system to run the BH properly and my question is what do I need to do swap from my current setup to the power beyond. Do I need to fork out the entire 360$ for the power beyond system, or can I buy piece parts to get it to work 'properly'??
thanks in advance
Mark
   / adding Power beyond to tractor with SCV #2
Does your 2 spool valve at the rear have a PB port?
There is probably a PB line coming from the side of the tractor going to the IN port of your 2 spool valve.
Remove that hose and add an extension hose to the back with a male QD on the end. Hose from the BH IN port should have a female QD on it.
This is your new source for the BH. The return from the BH can go directly to tank, or any return hose using a tee.
3pt will not be available with BH attached, unless you configure it differently.
When you are not using the BH, plug together the two hoses at the
Hydraulics:
Type: open center
Capacity: 6.8 gal [25.7 L]
Valves: 5
Pump flow: 8.6 gpm [32.6 lpm]
Total flow: 13.9 gpm [
   / adding Power beyond to tractor with SCV #3
Is it possible to put a "Y" or "T" fitting on the PB port, so that you can run two separate units such as a remote and the 3pt? And does the return line from the "out" port need the same pressure rated hose?
   / adding Power beyond to tractor with SCV #4
You can not use a tee fitting in a series circuit, as the flow will go to the lesser resistance.
However, you could install a switching valve and switch to circuit A or circuit B.
There are also splitters that will split the flow equally.
There are also priority valves that will provide a fixed flow to one circuit and the remainder to the other circuit.
Return hose does not have to be rated as high as the pressure hose.
In a tractor series hyd circuit, the flow would go something like this.
Pump, FEL valve, remote valve, 3pt, tank.
sorry for not responding quicker, had to take my travel trailer in for service and have been using all available light after work to cut down the dead trees that were near the TT when it's parked. Anyway, not sure what a PB port is, and not being able to raise and lower the 3pt would be a problem I think with the BH attached. I'm hoping that I can piece meal the power beyond system and get it to work. I assume I'll have to remove the lever to make this happen. I need to study the drawings a bit.
   / adding Power beyond to tractor with SCV #6
I'm not sure if your BH is the same as the woods 3pt BH I just got rid of but I couldn't use the 3pt with the BH hooked up. The lift arms and the top link were connected by a 3pt frame and if you lifted up on the position control lever you would blow the pressure relief valve instantly.
I had everything hooked up and was able to raise and lower the 3PH with no problem. Think I'm going to break down and buy the PB kit and install myself.
   / adding Power beyond to tractor with SCV #8
So when you put the BH stabilizers down they just push up the 3pt lift arms? Do the stabilizers lift the rear tires off the ground? My little woods BH stabilizers would pick the tires up off the ground on my 3000 and my brothers 1715 (6") without any problem.
I busted a hose first time I used it and putting a new hose on tonight. It's pretty big and I think it will pick it up no problem. Also found out that I have what they call a 3rd SCV kit. So still trying to figure out what I need instead of the entire power beyond kit.
   / adding Power beyond to tractor with SCV #10
Power beyond is a plug that goes in a control valve. I think you are talking rear remote hyd. couplers and a valve.
2016 Chevrolet Sonic LS Hatchback (A53424)
2016 Chevrolet...
2013 Great Dane 53ft T/A Reefer Trailer (A51694)
2013 Great Dane...
2023 HarbinGer V3 Plus 8KW S/A Towable Light Tower (A52377)
2023 HarbinGer V3...
2021 Chevrolet Silverado 1500 4x4 Crew Cab Pickup Truck (A53422)
2021 Chevrolet...
2019 MACK P164T DAYCAB ROAD TRACTOR (A51406)
2019 MACK P164T...
