I have a 2010 JD 3720 and recently purchased a used ARPS 728 backhoe attachment. I only have dual SCV on the rear (not sure of the correct name, but requires you to pull the lever to get Hyd fluid to flow). I can use the BH if I bunjie cord the lever in the up position, but obviously this isn't a good long term position. I need a power beyond system to run the BH properly and my question is what do I need to do swap from my current setup to the power beyond. Do I need to fork out the entire 360$ for the power beyond system, or can I buy piece parts to get it to work 'properly'??
thanks in advance
Mark
thanks in advance
Mark
