ADDING P/S TO KIOTI LB2204
   / ADDING P/S TO KIOTI LB2204 #1
1FOX
kioti lb2204
Has anyone ran anything off the splined shaft off the front of the balancer, am looking to run a power steering pump, adding a rack style p/s set up
in the early thinking stages
thanks
   / ADDING P/S TO KIOTI LB2204 #2
Think about this first. Do you have a pulley that is not used - i.e. crank having two grooves? Go to your local parts store, find a power steering pump off a 89 Ford Mustang, make a couple brackets measure for belt, order couple hoses and now you have power steering. This is a very low hp draw and should give you desired results.
   / ADDING P/S TO KIOTI LB2204 #3
Just wanting to know if you added the power steering I know that there is a power assist option out there but don't know what it consists of
2019 Ford F-550 (A55973)
2019 Ford F-550...
1981 LINK BELT HSP 8028 (A58214)
1981 LINK BELT HSP...
Pace American MW8516TA2 T/A Enclosed Concession Trailer (A56857)
Pace American...
NEW Wolverine Skid Steer Auger Drive And Bit (A59000)
NEW Wolverine Skid...
Tafe 45DI (A53317)
Tafe 45DI (A53317)
13045TX (A55973)
13045TX (A55973)
