ADDING P/S TO KIOTI LB2204
   / ADDING P/S TO KIOTI LB2204 #1
1FOX
kioti lb2204
Has anyone ran anything off the splined shaft off the front of the balancer, am looking to run a power steering pump, adding a rack style p/s set up
in the early thinking stages
thanks
   / ADDING P/S TO KIOTI LB2204 #2
Think about this first. Do you have a pulley that is not used - i.e. crank having two grooves? Go to your local parts store, find a power steering pump off a 89 Ford Mustang, make a couple brackets measure for belt, order couple hoses and now you have power steering. This is a very low hp draw and should give you desired results.
   / ADDING P/S TO KIOTI LB2204 #3
Just wanting to know if you added the power steering I know that there is a power assist option out there but don't know what it consists of
2001 KENWORTH T800 TRI AXLE TANKER TRUCK (A51222)
2001 KENWORTH T800...
2021 Kubota RTV X900 4x4 Utility Cart (A50322)
2021 Kubota RTV...
2014 Ford Taurus Sedan (A50324)
2014 Ford Taurus...
IF YOU BID ON AN ITEM YOU MUST PAY FOR IT!! NO BACKING OUT AFTER IT IS SOLD!! (A50774)
IF YOU BID ON AN...
2025 CFG Industrial TK35R Mini Track Loader Skid Steer (A50322)
2025 CFG...
2014 International DuraStar 4300 Terex BT3063 30,000LB Crane Truck (A48081)
2014 International...
