adding oil to the rear end of a kubota
   / adding oil to the rear end of a kubota #1
case245
Platinum Member
pa
kubota 7040sud
i have a kubot 7040sud it is low on rear fluid hydro oil what brand other then kubota can i use without voiding the warrenty the kubota brands to expensive for me to run 45 mins to the closes dealer for a quart of hydro oil
   / adding oil to the rear end of a kubota #2
Tractor Supply Center (TSC) carries a Travelers brand that states it meets Kubota specs at around $50 for 5 gal...2 gals were $23.
i need about a quart i only hope its not dry if it is its going to dealer its under warrenty
   / adding oil to the rear end of a kubota #4
IMHO.. on a warranty based machine.. I'd go with oem fluids.. just because.
it's usually not hard to stock some of what a machine needs to eat. I generally like to keep at least 5g of utf fluid on hand.. and 5g of gear oil.. and 3-4 gallons of engine oil on hand at any one time.
i surely would not buy utf oil by the quart. I don't even like buying it by gallon or 2 gallon.. too expensive that way.
soundguy
   / adding oil to the rear end of a kubota #5
Most of this only meets UDT not SUDT
Livestock Hay Ring - Round Bale Feeder (A55218)
Livestock Hay Ring...
PALLET OF SCAFFOLDING (APPROX. 7 PC) (A52706)
PALLET OF...
2007 International 4400 2,000 Gallon Water Truck (A52377)
2007 International...
CATERPILLAR 308E2 CR EXCAVATOR (A50458)
CATERPILLAR 308E2...
2015 Peterbilt 320 T/A EZ-Pack Front Loader Garbage Truck (A54814)
2015 Peterbilt 320...
2012 Ford F-350 Crew Cab 4x4 Pickup Truck (A53422)
2012 Ford F-350...
