Oil & Fuel Adding oil to 1974 MF135
   / Adding oil to 1974 MF135 #1
Michael262
waynesville, ohio
1974 MF 135
I just purchased a 1974 MF 135. I need to add a quart of oil but do not know where to add the oil. There is a cap to the left of the dip stick that I screwed off but I want to make sure it is the correct place. Be kind.
Thanks
   / Adding oil to 1974 MF135 #2
i don't have one. but many tractors either have a cap in the valve cover area, or the timing cover area.. still others have it at a block breather with removeable cap..
   / Adding oil to 1974 MF135 #3
I bet you use a GPS to get home.Of course it's the cap.
   / Adding oil to 1974 MF135 #4
You are correct. Dumb questions are the one's you don't ask.
Just curious, 8speed or multipower gearbox?
Beggar. Jerk! If you don't have nice things to say, stay off this site.
   / Adding oil to 1974 MF135 #7
Fill Cap by the injection pump.
   / Adding oil to 1974 MF135 #8
3 +3 =6 speed
Hydraulic Hose and Fitting Replacement Pack (New/Unused) Est Retail Value $2,650 (A59225)
Hydraulic Hose and...
2288 (A58376)
2288 (A58376)
LEINBACH SCOOP PAN (A52708)
LEINBACH SCOOP PAN...
(APPROX 15) 2" X 6" X 20'- 3/8" THICK METAL TUBING (A54757)
(APPROX 15) 2" X...
Giyi Excavator 44" Rake (A57149)
Giyi Excavator 44"...
2012 Ford F-750 Pak-Mor 16 Yard Rear Loader Garbage Truck (A56858)
2012 Ford F-750...
