Adding OE front aux lighting kit to 4105
   / Adding OE front aux lighting kit to 4105 #1
voltedge
macon,ga
kubota
When building my 4105 on the JD site, it stated that the front aux and rear aux lighting kits were not compatible with each other. I remember reading something about the factory light switch not being able to handle all of them. I already have the rear aux work light , but really wanna add the other two fronts to angle towards each side of the tractor. Anyone else do this anyway with any luck? I figured that I can just add a relay like a vehicle uses on fog lights and run a direct hot wire from the battery to the lights to eliminate any possible overloads to the factory wiring. I don't accept the "it can't be done logic" because there's always a way to do anything if you want to take the extra effort.
   / Adding OE front aux lighting kit to 4105 #2
Agreed! A relay will take the load off the switch.
Thanks! I thought so. I have the front light kit ordered and I have to get the relay and wiring done now.
   / Adding OE front aux lighting kit to 4105 #4
Using a few kits, I just installed three lights -- two forward and one rear. The instructions said the switch could operate three, but not four lights. It was a simple install -- just fed the color coded wires down the inside of the ROPS and plugged into the matching color connector.
2008 FORD F-250XL SUPER DUTY EXT CAB TRUCK (A51243)
2008 FORD F-250XL...
UNUSED X-STAR SKID STEER 72" LAND PLANE (A51243)
UNUSED X-STAR SKID...
Whisperwatt 45KW Towable Generator (RUNS) (A50774)
Whisperwatt 45KW...
2014 CATERPILLAR 306E EXCAVATOR (A51242)
2014 CATERPILLAR...
2008 CATERPILLAR 140M VHP MOTORGRADER (A51242)
2008 CATERPILLAR...
UNUSED X-STAR 101" X 25' BRIDGE PLATFORM (A51243)
UNUSED X-STAR 101"...
